How long can you run WOT
basstender10.6
I have a 1999 evinrude 5hp 4 stroke on my basstender 10.6. The boat is slightly under powered so I have to run it fast most of the time. My question is how long can I run it at WOT before it will overheat or do any damage? I usually run WOT for 25 seconds then lower it down to 3/4 because I already overheated it once.
coolguy147
Re: How long can you run WOT
you have other problems. when was the last time you serviced your cooling system? you should be able to run WOT all the time without it overheating.
foodfisher
Agreed, WOT till it runs out of gas. Overheating is a reason for concern and immediate attention.
