hootchieman
- Apr 9, 2003
- 16
I have a 2000 130 horsepower johnson.Im getting water in two top cylinders{#1-#2}.i did comp test before pulling heads and all cyl were 135-145 psi.When i pulled heads and examined gasket there was a perfect seal,no breaches found.this all came about when i noticed the engine running very cold{discharge indicator stream never gets even warm!}Could the block have cracked over the winter,I thought all water drains out in down position.In the leaking cylinders one of the ports is very milky,but not sure if intake or exhaust.does looper have 2 exhausts and 3 intakes.Where else can this water be coming from if not the head gasket or a crack?Before i pull apart
