Re: How to backing down the ramp
everybody has made good points, just want to add a couple
dont be afraid to turn around and look at the trailer, dont try to just back in with your mirrors, ive seen many boats hit the edge of the dock or fall of the ramp because someone wasnt paying attention, hell sometimes ill stick my head out the window, or even open up the door and look back there to check progress. (mainly because its a pain to see over the top my truck tool box and tailgate with an empty trailer!)
also, this may just be me, but i try, when possible, to use a ramp with a dock or pier along it, and i will use the edge of the pier as a straight line for backing in.
MAKE A MENTAL CHECK LIST!
when you get to the launch, TAKE YOUR TIME!
get out the truck, get into the boat and check to make sure you have everything in the boat and when it comes off the trailer, you wont have to make 5 trips back to the truck to get things
while your waiting to launch, start undoing your tie downs
ie: transom straps, bow straps, transom saver, put in your plug, etc etc
another thing i like to do, if the launch isnt too busy, ill back the boat far enough in the water so the water pick up on the motor is submerged, and i will start the motor and let it run for a minute to make sure everything is good.
two most important things i can stress, PRACTICE AND CAREFULLNESS!
im sure a lot of us here have been stuck at a launch waiting for someone to put in or take out, and it seemed like forever, knowing in our heads we were cussing the whole time, but think about it, when your putting YOUR boat on YOUR trailer, do you want someone rushing you? dont you want to take your time and make sure your rig in on your trailer right?
just remember, most (not all) boaters have a great degree of courtesy, and will even help you launch or land your boat, and they dont mind if you take a few minutes longer because they understand why.
good luck and great boating!
