how to get to get impeller out?
dkmaley
Re: how to get to get impeller out?
does anyone have any clues ,pictures,on how to remove the impeller on a 402E
40H.P. 74-76 help!!!
It's a three step process. 1) Drop lower unit. 2) Disassemble pump and replace impeller. 3) Reinstall lower unit. If you need more help than that, you need a service manual for your engine. You can find them at your local library, or you can buy them on line.
Unicorn
If you search iboats forums, you will find very accurate instructions from years ago on this procedure. The HARDEST part will be getting the Lower Unit off if it has not been done for over 3 years. Some of these oldies did not have a Stainless steel drive shaft and became stuck in the top spline.
Also, there are a few details pertaining to each model such as the gear selector shaft connection and what gear is best to leave the motor in for both removal and installation. Make sure you lightly grease the top spline and line up the water tube. Don't lose the impeller key..
I will try to did up some old links from my previous life here..
dkmaley
thanks for the info ,this type to my understanding were only made from 74-76 I already have the lower unit off and now to get the pump out. thanks again
dkmaley
dkmaley
thank you:):)
dkmaley
thanks thanks:):):)
