how to remove starter?
Re: how to remove starter?
Ayuh,... Disconnect the battery, disconnect the wires on the starter, remove the starter....
telstar1
If its a delco starter(later models)there will be 2 bolts horizontally thru to back of bell housing.
You will need a wrench on head at back of bell housing and a socket/extension on front side nut. One of the nuts is sort of hidden by solenoid.I think you can get at it without removing solenoid but its a bit awkward. I customized the nut on mine by welding a handle on it makes job a breeze.Earlier model had I think prestolite starters as far as I know they removed same but Ive no direct experience.
lynnboy021
i removed the bolts on the back but you can still see the bolt. do i have to rermove the plate or is the bolts in the flywheel housing? i have the service manual but it does not show how to remove
telstar1
Not clear what you mean. You removed them but you can still see them?The bolts you are looking for are I think about 4 inches long,take either a 9/16 or a 5/8 wrench,head of bolt is aft,nut forward, once nut is off bolt will be loose in hole. Check for a starter support bracket near front of starter(mine didnt have one). If thats off or not there, starter should come out forward. It might be stuck. Rap it with a dead blow hammer or a 2x4,side to side, up down etc till it comes free. Shouldnt take much.
lynnboy021
sorry. ok the bolts on the bell housing i remove all the bolts that looks like its going to the starter. so there is no more bolts back of the motor but the starter still has bolts so maybe its not bolts its maybe studs and you have to remove the nuts? idk i am looking all over the net for pics or video my last opiton is i am just going to remove the motor...
lynnboy021
ok so i removed both nuts off but the starter does not wanna come off its like welded on its really not but looks like. motor is making me nuts.
achris
More fish than mountain goat
did you remove the bolt on the support bracket at the front of the starter motor?
Bt Doctur
Don S
BT, A 488 is a 470 engine, not a chevy.
lynnboy021
lol i smash the crap out of it with a 3lb hammer anything bigger wont fit lol
dccordell
If it's the same as the 470 and is the prestolite starter, all you need to do is remove the two bolts on the rear of the starter, and remove the nut or the whole bracket on the bottom of the starter (if it has the bracket) and the thing will slide forward out of the housing. I've read that those things get rusted where it slides into the flywheel housing and makes it a real pain to get out. Maybe try soaking it with some PB Blaster for a day. You should be able to see where it slides into the housing. It is a precise fit, so it doesn't take much to get stuck.
Mine slid out without too much force, lucky perhaps...
lynnboy021
well later today i am going to try and give it another shot the only thing is that my boat is up for sale and i dont wanna sell a boat that is not working cuz i dont want the person to be on the water and the boat does not wanna start. i will just have to take the boat off craigslist intill the bat it a turn key boat but it sucks cuz i been getting alot of emails to look at the boat well i will update tomorrow thanks...
lynnboy021
so here is the update the starter did not wanna come out so i just took a hammer drill to it and broke the nose in half but at lest the starter came out now my ? is is there a auto starter i can just use the nose of it?
Don S
WOW, A true hammer mechanic. If you can't do it right, get a bigger hammer.
No, there is no auto stater for a 470 engine.
telstar1
IF its a Delco starter,(later 470s) Im reasonably sure the nose cone is common to several automotive starters. Not sure about the earlier Prestolite starters.
lynnboy021
don s i had no room for a bigger hammer i had cables hoses and all that other stuff so the hammer drill was the best tool. telstar um its a arco starter.. is 470 and 488 starters the same?
