Re: how to run a 2 battery system?
Actually, adding another battery will increase the cranking power. If you had the same cranking power out of just one than most of your trucks and heavy equipment would only use one battery rather than 2-4. The main reason trucks and equipment use multiple batteries rather than one large one is the cost of replacement is alot cheaper. Meaning if one went bad you don't need to replace all of them. Rather than adding an extra though, look into getting a battery with a higher CCA rating. The battery will likely be larger but will not be taking up as much room as two batteries. Plus than you won't have the added expense of the cables.
