I hit a buey and cut a blade on my prop in half and bent the shaft very little. I was about 5 miles out (lake) ran about 3/4 all way back. I put a new prop on it and it seems to do ok with a land test no vibration at 3/8 speed. I changed lower lube oil and did not see any water in it after I hit the buey. After I tested the motor on land some oil did leak out from the exhust hole (prop area)not much at all though but, I know that is bad It is a 84 150hp Evenrude been a great motor till now WHAT SHOULD I DO??????? Thanks for any help or idea's you can give me.
