I/O (Sterndrive) Conversion to Outboards
tpenfield
For those contemplating making a thick plate of fiberglass as I am doing . . . Don't :ROFLMAO:
My method has been to lay up CSM & 1708/1808 in alternating layers. I was originally thinking about 22 +/- layers. When I get to 3/4" of build-up, I place some plastic sheeting over the fiberglass in the cavity and use the 1" Coosa piece that I cut out as a 'tamp' and apply some weight to flatten the fiberglass out, so that it is even. Here is a picture of the cavity filled to 3/4" , 'flattened', and cured. . . . It has about 1/4" more to go to be level with the surrounding Coosa.
Since my shop is fairly cold for fiberglassing (60˚F), it takes a while for the resin to 'kick' . . . but once it does . . . holy cow . . . quite a bit of exotherm ! :oops:
The piece gets up to about 120-130˚F.
After curing, I add more layers of fiberglass to get up to the 1" thick. What I am finding is that I need about 25-26 layers of glass to get to the 1" . . . probably because of the CSM layer is not as thick as the 1708 and 1808 layers.
I hope to be done today with the inserts and then moving on to the next thing . . . which may be glassing in of the planing surface.
Hey Ted, Mercury is showing the new 808 hp outboard at Miami. you could get by with one motor.
tpenfield
Getting pretty heavy eh..:)
Yes . . . But all for a good cause :p
My latest estimates, based on the recent changes are
Bracket ~ 500 lbs.
Hull Modifications/bracing ~ 200 lbs
Very little weight reduction overall . . . about 200 lbs.
Ted, how many cases of beer will fit in the bilge where the two 6.2's used to sit?
Did you figure in the weight of "provisionings" in your calculation?
tpenfield
I got the transom inserts done . . .
Here is a picture of the process . . . rolling out each layer to ensure that there are no air pockets. I add the resin (~ 5 oz. ) for each layer and then lay the cloth on top of it so the resin soaks upward into the cloth (or mat), forcing the air out.
It is a tedious process, but it works. I calculated the glass-to-resin ratio using a volume calculation. Each cavity is 275 cubic inches and I used a gallon of resin (230 cu. in) on each. So, the glass content is about 16% by volume. It seems pretty low, even though I painstakingly rolled the glass to force the resin up from the layers below.
Here is the transom with both inserts glassed.
alldodge
Looks good, did ya ever think about aluminum plate or honeycomb aluminum plate?
tphoyt
I learned about that hard way as a kid. I glassed over an aluminum plate and it delaminated in the first winter and I was living in Fl at the time. To much movement between the 2 different materials from the temp change.
