I finally had a chance to try out the new trim tabs this last weekend.
Night and day difference, and it's nice having functioning trim sensors again.
For the most part i never needed to adjust the engine trim, the boat just went!
The auto trim pro feature is neat once i had it programmed.
The more i let it run, the better it got.
I also liked how when under way, it sensed chop and deployed to smooth it out, you can watch it work by the status lights on the controller.
Pretty neat
A few times i had to take over, like when they deployed at weird times and did weird things. Or when they wouldn't deploy when i wanted them to.
It got better as the auto feature learned, so I probably just need more time with it in auto.
Setup was frustrating,
First google won't resolve the bennett website for some reason, so i got different versions at first.
Later i used duck duck go and it found the bennett site right away.
Two versions of the instructions depending when the controller was made.
On the water doing the setup, i saw one step where before I swear there was two steps.
Programming never completed so i found it on youtube.
I kept missing step one where you set the stationary position, so that got frustrating until i slowed down and watched the video from the start... lol
Then finally all steps completed, and the blue lights turned off indicating Programming has been completed.
Then Programming the fav buttons so I could start messing with the auto feature.
I like having the control, and the auto feature.
Even with the tabs retracted the boat planes faster.
Running the tube was also much smoother, never needing to use engine trim.
I feel like some of the auto weirdness would be resolved if the controller had speed data, but it still does a great job once it started figuring the boat out.
