Re: impeller installation
That motor does not have a thermostat. If you are not getting water from the peepee hole, then you did something wrong. Impellors only spin one way, so there was no way to get it backwards.<br /><br />Look inside the housing for pieces of rubber from previous impellors, make sure all the little passages under the impellor plate ( dont know the tech term) are clean. Make sure the "key" is in the impellor so that it will spin when the shaft is spinning. Lastly make sure that you have the pickup tube properly inserted.<br /><br />To make re-assembley easier, put the motor in forward before dropping the lower unit. That way there is no guess work when it come to lining up gears.
