Info on Auto Trimtab Control From Bennett
adam24601
Hi Everyone,<br /><br />Does anyone have the auto tab control for their bennett trim tabs? Any info out there on how they perform..how hard or easy to install..and how well they work? I would appreciate it.<br /><br />Thanks,<br /><br />Adam
cuzner
Re: Info on Auto Trimtab Control From Bennett
I've been thinking about putting them on myself.Kinda pricey,but if there worth it might do it.<br /><br /> :eek: Jim
adam24601
Yeah..they are pricey....that is why I want to hear from someone who has them or knows about them.<br /><br />Adam
adam24601
Doesn't anyone have these?<br /><br />Adam
mollyog74
come on, anyone? Im interested too? Will they help with ocean swells, or just skiing?
Jdeagro
iboats.com Partner
Molly; <br />you are on the wrong topic. The auto trim control system for these trim tabs is an add-on accessory to their helm controlled trim tabs. You will first need to have the trim tabs. Search on this site for "trim tabs".
mollyog74
thanks nauti,<br /><br />hey you never got back to me on the other thread...or did you, I'll go see if I can find it. If not maybe I'll start a new one.<br /><br />Thanks again.
burp
One of my current boat projects is to install the Bennett Auto Trim Control and Auto Trim Retractor on my boat which has Boat Leveler Insta-trim tabs. <br /><br />For the Auto Trim Retractor (ATR) it's a simple "box" which has 6 wires. The wires go to: a switched 12 volt source such as ignition switch, ground, a 12 volt 20 amp power source (such as the existing trim tab fuse) and the remaining 3 wires go to existing trim tab wiring harness.<br /><br />For the Auto Trim control (ATC), it's a little more involved but still quite easy to connect. The ATC consists of a control panel, attitude sensor module, central processing unit (CPU) and an ATC module. The ATC and CPU modules connect together and require 2 different power sources just like the auto trim retractor does. The control panel has a 6' cable attached which connects into the ATC module. The other 4 wires connect into the existing trim tab wiring harness. The attitude sensor has a longer cable (maybe 20') which plugs into the CPU module.<br /><br />How does it perform?????? I don't know since I have not completed the installation yet. Give me a couple of weeks and I'll let you know.
