SkaterRace
Master Chief Petty Officer
- Mar 20, 2016
- 835
I have a Blackfin 212CC (pretty much exactly the same as the 222CC they have now) and am looking to install a Lowerance Recon 72 inch on the bow. I've decided on this motor because it works with the Simrad MFD's I have (Go 9's). For batteries I am thinking 2x 36V 50AH lithium from LiTime. When I was talking to the guy who will install it for me in the fall he was origionally thinking of using my bow seating to install the batteries. I was not a huge fan of that because that is literally my only usable storage on the boat.
I do have a deck hatch in the bow though I suspect that isn't dry enough to put them in (what even should go in that hatch? I've never found a use for it) and I have a head in the console which makes installing them there kinda hard. I do have a spot along the side that stores the table which I almost never use. We debated installing them there if the batteries fit.
Past those locations is the stern where on the one side there is an open spot for a water tank - fresh water washdown - that my boat does not have. I originally thought to put them there though he says the wiring would need to be massive and the weight that far back likely isn't good as we normally run with a max of 3 people - 2 at helm and 1 on bench or vise versa.
In such a small center console with limited options, what is likely my best option for putting the batteries for the trolling motor? Also anything "extra" I should ask for to be installed when I get the trolling motor installed?
