Installing a trolling motor on a 21ft CC
SkaterRace
Master Chief Petty Officer
I have a Blackfin 212CC (pretty much exactly the same as the 222CC they have now) and am looking to install a Lowerance Recon 72 inch on the bow. I've decided on this motor because it works with the Simrad MFD's I have (Go 9's). For batteries I am thinking 2x 36V 50AH lithium from LiTime. When I was talking to the guy who will install it for me in the fall he was origionally thinking of using my bow seating to install the batteries. I was not a huge fan of that because that is literally my only usable storage on the boat.
I do have a deck hatch in the bow though I suspect that isn't dry enough to put them in (what even should go in that hatch? I've never found a use for it) and I have a head in the console which makes installing them there kinda hard. I do have a spot along the side that stores the table which I almost never use. We debated installing them there if the batteries fit.
Past those locations is the stern where on the one side there is an open spot for a water tank - fresh water washdown - that my boat does not have. I originally thought to put them there though he says the wiring would need to be massive and the weight that far back likely isn't good as we normally run with a max of 3 people - 2 at helm and 1 on bench or vise versa.
In such a small center console with limited options, what is likely my best option for putting the batteries for the trolling motor? Also anything "extra" I should ask for to be installed when I get the trolling motor installed?
rolmops
It is very important to have the right weight balance in your boat.
For trailering you need some serious weight on the front end to prevent serious accidents while trailering. Also, with too much weight on the rear you will have trouble with your hole shot because the front of the boat will come up way too much.
If you decide to put the battery in the closed bow compartment you should look sealed marine batteries because the bow of a boat tends to get banged up more than the rear and you do not want a closed compartment to fill up with nasty gas escaping from the batteries. In addition, if you choose the front it is also a good idea to buy a plastic type battery box, so any leakage will be contained.
When I moved the batteries on my boat forward, a cable length of 24 foot with all the turns involved, I used 1 gauge wire. This was for making sure that 50 amps sometimes needed would make it to the starter without overheating the cables.
I added a website that will explain what gauge of wire you will need for what length of cable.
good luck
SkaterRace
good luck
Thanks, yeah the back isn't ideal for weight, though up front the only spot that seems to make sense is in the deck which seems far from ideal. In terms of gas, I don't think that's a problem with lithium batteries?
rolmops
Personally I would go with AGM or EFB batteries. Both are lead acid ,but properly sealed ones.The Lithium ion often need a different type of charger and they are a bit problametic with the charging system on older outboards
SkaterRace
Any space under the console ?
That would be the one spot I said "I have a head in the console which makes installing them there kinda hard. I do have a spot along the side that stores the table which I almost never use. We debated installing them there if the batteries fit." in my OP. It is essentially a storage tray that would likely need some re-enforcement to hold them. For deck space in the console I do not unless you went each side of the head for a battery.
SkaterRace
I have a 2019 Mercury 225XL, and the reason I wanted to do Lithium was to keep the weight down. An AGM based setup would be ~225lbs where the Lithium is going to be ~66lbs. With how small my boat is that weight difference feels noticeable.
I would go up under the seats in the front as my first thought. close to the speakers and under the cup holders and back-rest post
second location would be under the deck in the front hatch area.
would require building a ledge in the hatch area to hold them.
the head area is a bit small, that would be my last location of choice.
what ever bracing you use to install the batteries, remember, these boats in chop are subjected to 3-5G load slamming into waves. so that 36# battery becomes a giant sledge hammer wanting to break your boat.
thats where the front storage would shine. add a bit of foam under the tray down to the hull to hold them and youre golden.
I would lean toward smaller Lithium batteries for packaging over lead acid or AGM.
cyclops222
I would definitely Put the batteries inside of a Black plastic battery box with a matching cover. Put pieces of 1 1/2" square wood pieces around the battery box or boxes. Some Silicone Rubber to bond the wood pieces to hull deck. Install. Ratchet straps over each battery box snuggly. That set up allows servicing acid or LIFEPO4 batteries.
airshot
lifePo4 batteries all the way....best move I ever made with batteries ! Watch the sales, my battery was the same cost as two deep cycle LA batteries and the pull has twice the power and 1/4 th the weight. Run time is almost 3x as long as the LA batteries. Just be sure to use the correct charger on the Lipo batteries, you do not want to mess around using your engine to charge the Lipo batteries!! If you mount them near the front, be sure there is some cushion under the lifepo4 batteries to absorb the pounding, I use a 1" thick foam pad that came with my battery. I know lots of boaters that have made the switch from LA to lifepo4 batteries....not one person is sorry !
