Re: Johnson 9.5 Overheats
Hi jwmcnic, I was wondering if you use this in fresh or salt water. Either way, there is a thermostat in the motor, it is located under a round cover on top of the cylinder head. The 9.9 is a little different design, but you could have that same problem. The head gasket could be leaking, you may have to change that. I would start in these areas after you have checked the waterpump.
