DamianJP
- Mar 25, 2008
- 612
Re: Last try for help with 50 hp shift lever.
It sounds like the problem is in the control box. My nephew accidentally tried to shift the motor with the warm up bar not fully down and cracked a plastic guide/part in the control box and was giving similar symptoms. It finally broke fully and made it worse to were I couldn't even move the level at all. Not saying you broke it this way too but the parts in the box can get brittle and weak and break "Just cause".
Had to rebuild the control box couple of plastic parts, a guide and some other stuff.
Is your control box like this ?
http://www.stripersonline.com/ubb547/image_uploads4/S2010151.JPG
If so its the same as mine and I think you should focus on the control box. I know it kinda of happened around the same time as you dropping the lower unit but you disconnecting the cables and it still happening rules out alot.
2 manuals Ive found but cant find the 50ESL75 (B) one
Mabey someone can chime in make sure these are for your motor too.
http://www.marineengine.com/parts/p...09&ptype=Service+Manual&Engine=&Model=50ESL75
http://cgi.ebay.com/1975-Johnson-Ou...ultDomain_0&hash=item588c278615#ht_753wt_1139
And Im charging my battery for my camera as I type ill get pictures of the control box sections from my manual you can start to check stuff, hang in there.
PS: Don't stop posting on this forum. No one is getting annoyed .
We want you back on the water !
DamianJP
DamianJP
