Re: Lower Unit Compatibility
started out as: spin prop, hear a slight "growl", then started to "pop" while under way, pulled it home, drained the lube, had water in it, and numerous shavings on the plug. also noticed play in the prop shaft, not in and out, but up and down, shaft seems to have a noticable wobble to it.
