Re: m/w sea king 12 hp.how do i get the top off.
The plate is usually on top of the mounting bracket.Is that a full gear shift model?If it is I have the 5 hp same basic setup.The 2 sides are seperate from the top.In the center front usually a high speed mix knob and low speed knob Usually no need to remove except to prevent damage.You will have to remove the choke knob.
Sides have 2 screws Don't remove the side trim screws.Just the larger side screws.Side screws may be retained by clips no need to remove.Loosen screws.Sides should be loose and separated. It will appears side won't clear shifter,it will.I believe forward or reverse. You have to diddle with it.
You can remove the rewind (4 screws) but not tank Fuel line won't allow.
But with tank loose maybe sides will be easier.
