Re: m60b steering bracket is REALLY stiff
thanks guys...
well i took the power head off and then the mid section off the bracket
then i heated and beated to get the lower mount off the shaft -might need to get a new one of those as it was really stuck and i had to cut the lower engine mounts off because the bolts woulnt come out im taking it to welding school tomorrow to take the acetlyne torch to the bolts and do a little build up welding
i got the shaft knocked up about an inch so im almost home there im thinking im gonna hook the engine crane to the shaft and lift it out that way so i dont booger up the bottom end of the shaft
now i need:
lower engine mounts
power head gasket
possibly the lower bracket
good news is before i did all this teardown i fired it up today she purrs like a kitten
(i rebuilt the carbs earlier this week)
question though?
i put a new housing and impeller in it changed the gear oil (looked good) should i go ahead and do the thermostat ?
