There should be a small hose running from the top of the tank to a thru-hull vent fitting, usually the hose runs runs parallel to the main fuel fill hose and the vent is close to the main fill. Post some pics.
here are some pictures. I was able to find the line you mentioned and i dont think that it is plugged in any way because the first time i filled the boat up at the gas station i didnt know when to stop and gas started backing up out of the little vent hole in the back of the boat (it is the small chrom cap in the pics). I put the cap on pretty tight thinking that was how it should be so should i loosen it some? i was afraid water would get in or it would be to loose and rattle off. I wont be able to take it out for a couple weeks as im not going out on a holiday weekend, too many drunk idiots out on the water. But if this coil, fuel filter, loosening the fuel cap doesnt work im out of suggestions so is there anything else i should check while its in my drive way?
Fuel Fill Cap
vent cap is the small chrome cap to the left
close up of the vent cap
fill line is on the left and the vent line is on the right
both lines running up the side of the engine bay
Vent line runs right to the vent cap
