Mechanic tricks?
nola mike
Seeing the "what tools are these" thread...
Following up with a "tricks that old people know".
I'll start: putting the closed end of a box wrench on a bolt, and using another box wrench on the open side as a breaker bar. Easier said than described. Ok, here;
Same vane, I have a few pipes that fit over the ends of my ratchets to use as breakers. Or over my breaker bars.
nola mike
Same here
Well, same here but my 15 yo didn't know about it. Just something you pick up. How about welding a nut to remove something stripped, using a torx bit to remove a stripped Allen screw, etc. A lot of obvious stuff that might not be obvious, or just didn't get picked up. Especially diy'ers without anyone teaching them. Ran into that fishing/crabbing, never had anyone to teach me.
Mc Tool
Some butchers out there I see😁😁. I have never and never will couple two r.o.e (ring open end )spanners together nor have I ever used a bit of pipe on a ratchet ,I may have once used pipe on a breaker bar but I usually go for a bigger bar ....like a ¾" drive breaker and an adapter for ½" socket . I have bashed a smaller sockets over a rounded nut or bolt and have used torx bits on a cap head screw . I keep cheap a socket set and driver bits for this purpose .such sockets have also been welded to make special tools . Old screwdrivers have been repurposed as pry bars and also as handles for special tools ( pix tomorrow )🙂
tpenfield
I often use a piece of pipe over the handle end of a socket wrench to create a breaker bar.
I also use an adjustable wrench tightened to the a square shaft of a screw driver to create some leverage on a stubborn screw. Otherwise I will use a manual impact set on the screw to loosen it.
Chris1956
Gee, most often when I had to resort to using the "Cheater Pipe", I broke the bolt. Last time was on my car's disk brake caliper support.
Luckily a propane torch broke the bolt (or what was left of it) loose and I turned it out with a vice grip.
Now using a vice grip may not be an old person's trick, but it can be effective.
Grub54891
I have a box of sacrifishal tools I get at garage sales. Cut, weld, bend and such. Make what you need!
