Mechanic tricks?
nola mike
Seeing the "what tools are these" thread...
Following up with a "tricks that old people know".
I'll start: putting the closed end of a box wrench on a bolt, and using another box wrench on the open side as a breaker bar. Easier said than described. Ok, here;
Same vane, I have a few pipes that fit over the ends of my ratchets to use as breakers. Or over my breaker bars.
nola mike
Same here
Well, same here but my 15 yo didn't know about it. Just something you pick up. How about welding a nut to remove something stripped, using a torx bit to remove a stripped Allen screw, etc. A lot of obvious stuff that might not be obvious, or just didn't get picked up. Especially diy'ers without anyone teaching them. Ran into that fishing/crabbing, never had anyone to teach me.
Mc Tool
Some butchers out there I see😁😁. I have never and never will couple two r.o.e (ring open end )spanners together nor have I ever used a bit of pipe on a ratchet ,I may have once used pipe on a breaker bar but I usually go for a bigger bar ....like a ¾" drive breaker and an adapter for ½" socket . I have bashed a smaller sockets over a rounded nut or bolt and have used torx bits on a cap head screw . I keep cheap a socket set and driver bits for this purpose .such sockets have also been welded to make special tools . Old screwdrivers have been repurposed as pry bars and also as handles for special tools ( pix tomorrow )🙂
tpenfield
I often use a piece of pipe over the handle end of a socket wrench to create a breaker bar.
I also use an adjustable wrench tightened to the a square shaft of a screw driver to create some leverage on a stubborn screw. Otherwise I will use a manual impact set on the screw to loosen it.
Gee, most often when I had to resort to using the "Cheater Pipe", I broke the bolt. Last time was on my car's disk brake caliper support.
Luckily a propane torch broke the bolt (or what was left of it) loose and I turned it out with a vice grip.
Now using a vice grip may not be an old person's trick, but it can be effective.
besides the various sections of pipe and tubes to turn ratchets into free-spinning tools needing repair or extending the length of a breaker bar, I also use two wrenches together to make a longer wrench
here are some of the hacks I have done over the years
a home made slide hammer for GM J-body half shafts. a 30# chunk of 2" wall tube on an 30" long 1-1/4" shaft with a 5/8" grade 8 bolt welded to it. manual says all that is needed is a 5# slide hammer. history proved otherwise
long bolts with the heads cut off to align a manifold / transmission / etc
a stack of laser cut washers and various bits of steel tubing and various sizes of hardened threaded shaft and nuts in my VW/Audi wheel bearing tool kit to press in new bearings while the spindles are still on the vehicle
a bit of electrical tape around a universal swivel extension to keep it from flopping about (because I didn't buy the ones with the spring around them)
a bit of painters tape inside the sockets to keep the nuts from falling into the depths of the car. also have a bunch of rare earth magnets I drop into sockets to hold nuts and bolts
a section of 1/4" hose to spin hot plugs out of a motor without burning your fingers on headers
old vicegrips with the jaws ground smooth and a hole drilled into them to drive dipstick tubes in place
a few old sockets with used #2 Philips bits welded to it to make rear brake caliper tools
section of aluminum pipe cut into a VW VR6 plug tool
grind the head of a garage sale wrenches to get it to fit into tight spaces
an old extension with teh end mushroomed out from using it to drive in seals and bearings. (turn the socket around)
cheap amazon borescope / endoscope in the tool box that plugs into my phone
welder to remove almost any broken bolt/tap/etc
welder to remove any internal bearing (just weld the race and the bearing falls out when it cools)
4" cut-off wheel to remove the ones that you cant get out with a welder
an un-lit propane torch and a vacuum gauge for setting idle mix
garage sale wood chisels for removing exhaust systems (they work about a dozen times)
Shop vac and a Tropicana orange juice bottle as a make-shift vacuum brake bleader
gallon of water and a cheap harbor freight flash light with some tape to make a room light when the power is out.
nola mike
These are great! I'm going to need to take some of the vw tools off your hands
