Re: MERC 7.5 H.P. TO 9.8 H.P. CONVERSION
Much more to the story. The intake and exhaust porting on the 9.8 is larger. Installing a larger carb will only make it run like crap. Lots of those motors around with busted up lower ends - find a good 9.8hp powerhead and go with that... Or, at the very least, a good 9.8hp block, as your pistons, rods and crankshaft would install fine. Only then would you be able to install the 9.8hp carb...<br />- Scott
