MERC 7.5 H.P. TO 9.8 H.P. CONVERSION
PICSTEVE
I WAS AT A MERCURY REPAIR SHOP THIS MORNING, AND HE TOLD ME THAT MY 1980 7.5 MERC. COULD BE CONVERTED TO A 9.8 H.P. WITH A CARBURATOR SWAP. IS THIS TRUE, OR IS THERE MORE TO THE STORY.
Laddies
Banned
Re: MERC 7.5 H.P. TO 9.8 H.P. CONVERSION
If that were the truth mercury would not have sold may 9.8 engines
Chinewalker
Much more to the story. The intake and exhaust porting on the 9.8 is larger. Installing a larger carb will only make it run like crap. Lots of those motors around with busted up lower ends - find a good 9.8hp powerhead and go with that... Or, at the very least, a good 9.8hp block, as your pistons, rods and crankshaft would install fine. Only then would you be able to install the 9.8hp carb...<br />- Scott
dajohnson53
I believe you could put a 9.8 cowling on it though and fake it! :eek:
bammgelo
I have a 7.5...<br />I enlarged ports, 9.8 carb but nothing appen<br /><br />the mistery are reed valves: in 7.8 opens 4 mm.<br /><br />I have machined crankshaft: now valves open 6.5 mm. Now I have 10 plus Hp.
