Celebrity86v190
- Aug 15, 2016
- 5
Hi, I have a 86 celebrity 190v bowrider. 230 mercruiser v8 and when I run the engine is have a steady stream of water filling the bilge. Only happens when running. Used flush muffs with water tured on full and no water comes out of hole. The hole has no threads and is located in the housing that the drive shaft goes through. https://youtu.be/2pMIFGppcGk is a quick video showing the problem.
Can someone tell me if I am missing a freeze plug ? If so what size? I cannot find any hoses that might have popped off and there doesn't seem to be any coupling device on the hole. It's a smooth bore about 1/4 inch in diameter.
