Thanks. I will do some more investigating to see if I can confirm if the transom is in bad shape or not. It would make sense that the leak got worse after I pulled the drive if that is the issue. Anything I can do in the meantime to seal it better? Or is this a total no-goI would say transom leak. Probably not the transom assembly though it might be. Most likely the transom is soft and needs to be replaced
I did already try this from the inside right below the transom plate... it didn't budge with the screwdriver. There is a transducer mounted on the rear of the transom. I will pull this off and see if any water comes out of the holes... Transom tap test doesn't give any red flags either. I may try to tighten the nuts a bit on the inside if I can reach them. Unfortunate to make this discovery at the very beginning of the season if it is true..If its soft there is no easy fix.
Take a Philips screw driver and try to press it into the transom. ON SECOND thought DON'T DO THAT. My thought is its soft, and if you push a screw driver into the transom it may turn into a really bad leak
Hmm I can try to get another look at that... This could occur even with the motor not running?Looks like in the video around the 0:14 mark the water is leaking from above the trim lines. Thus would indicate a leaking exhaust system. Perhaps the o-ring for the exhaust tube/gimbal housing seal? Or the exhaust tube corroded through?
Could also be something above the exhaust.
Yes, if the boat is in the water.Hmm I can try to get another look at that... This could occur even with the motor not running?
Corrosion I would doubt... boat has been in freshwater all its life. I will have to put the boat in the water again and take another video / look at exactly where the water is coming from. All I know is that it is much worse after pulling the drive and doing the bellows. Would be worried to go out on the water with the bilge pumping every few minutesYes, if the boat is in the water.
I wouldn't. Doesn't matter where the boat is used. Anything put in water will corrode given enough time. Add different elements to the mix to speed up the process. This is why there are different materials for freshwater anodes vs saltwater anodesCorrosion I would doubt...
Thanks for the insight, will definitely look around some moreI wouldn't. Doesn't matter where the boat is used. Anything put in water will corrode given enough time. Add different elements to the mix to speed up the process. This is why there are different materials for freshwater anodes vs saltwater anodes
If I run on muffs would this be a good way to narrow the leak down to the exhaust o-ring or not.. if it leaks on muffs, it is the o-ring?Tightening the bolts would not require rechecking alignment
Tightening the bolts may cause them to snap off IF they are corroded and have eroded internally. IMO, once something is old and starts leaking, tightening fasteners will have no effect
If the water is coming from the exhaust O-ring, tightening will not help
Or ring or corroded down pipe . also i think if shutters get burnt and lodged in there you may wear a hole in the pipe.If I run on muffs would this be a good way to narrow the leak down to the exhaust o-ring or not.. if it leaks on muffs, it is the o-ring?
Best bet is to drill holes in transom to see extent of rot.Went to tap around on the transom again.. dull sound and didn't get much bounceback on the lower left side of the transom on the outside of the boat. Assuming that is sign of rot and potential leak area.. The rest of the transom around the bell housing / bracket sounds good. Anything I could do to make it through the rest of the season before pulling the motor and doing the repair before next season? No flex in the transom itself from standing on the drive. The boat cruises around on a lake, spends most of the time anchored
The exhaust boot on the elbow correct?Maybe, the issue is when its in the water and motor stopped, the pressure is increased inside the exhaust. Running on muffs has very little pressure.
To make it a bit safe, remove the exhaust boot and stick the hose down the exhaust pipe letting water run out with motor off
