peter paul
- Jul 31, 2008
- 114
Re: mercruiser overheating
You do need to account for the missing parts of the old impeller... They could be lodged in the heat exchanger or the exhaust elbow. Blocking any part of either of those items will reduce the cooling on the engine (It'll overheat under load)... While you have the drive split apart check the water pocket cover....
Chris.......
If you don't know what a water pocket cover is.... -> http://forums.iboats.com/showthread.php?t=556903&p=3825409&viewfull=1#post3825409[/QUOTE i was having problem with my motor overheating and was advise to replae please help ce the water pump which i did before i installed the pump the motor was running fine. finshed installing the water pump now the engine wont start did i missed something. before i removed it i shifted to forward to remove the outdrive. did i do something wrong inside the outdriv
