BajabossJD
- Jul 10, 2011
- 138
Hello Guys,
I am having a issue with a connection problem in my main ENGINE-HELM connection. The key starter has been acting up (checked all connections behind dash..definitely a harness problem), but if I play with the harness while someone is turning the key, the engine turns right over. This harness has two large pins..black and red, and then has a pin pattern around the outside. The starter wire is yellow, but I cannot see what Pin it is tied to.. Does anyone know what pin number is linked to the starter? Also, I want to clean the female side of the plug as I think its a corrosion issue. Any tips to clean? Pipe Cleaner?
Thanks,
Joe
Thanks,
Joe
