coolguy147
- Jul 14, 2008
- 2,817
Re: Mercurys are fast! 1961 mercury 500
was wondering why the line and o sounded a bit funny? yeah those matched up perfectly with my mag and flywheel.
therefore all i need to set is the max advance right?
how did it go? hook OHM meter to positive end to the ground out stud then negative to ground. then turn the motor over? is it running while im testing this?
I stand corrected the TDC line on the flywheel is a straight liner and the line with a 0 on it is .235. My fluke Meter or Merc-o-tronic both read point flux from the mag. terminal, was the ign. switch disconnected or in the on position
