MFG rebuild getting started pics
kfa4303
Banned
Re: MFG rebuild getting started pics
WOW!!!! She's a 'bute! Can't wait to see her on the water, and the hardtop is to die for!
sphelps
Thanks kfa !
I can't wait to get her on the water and my wife feels the same way !:facepalm: :D
I gotta feeling that she's gunna fly with the 85 on there !
Trooper82
Thanks kfa !
No doubt about it...and even if she doesn't "Fly" I'm sure you will be soaring in the clouds with a grin ear to ear :)
Decker83
I'm sure you will be flying on the water and better yet you will be styling all the way from the driveway and on the water.
Woodonglass
Yeah, I WISH I had a 70 hp on the BF. The 40hp with 2 300 pounders up front really is NOT cuttin it! I gotta figure a way to get the 70 hp Tower of Power from Andgott down in Tennessee. My son and I might have to take a trip now that Gas prices are coming down.
sphelps
That would be a trip worth taking !;)
jbcurt00
Hmmm.... Hanging w/ WoodOnGlass for a couple of days, destination the Andgott boat yard....
Yeah, that'd be worth quite a few days on the road:cool:
sphelps
On second thought he might get the idea to come home and turn the BF into a PF !:eek: Stranger things have happened..:D
jbcurt00
That was his granddaughter's preference anyway I do believe. Maybe w/ purple unicorns:D
sphelps
OK I am planning on painting this allum gunnel pocket white with a black stripe down the middle. Is this sep ok to use for this? And how should I prepare the the allum before priming? This is a scrap piece It has a textured tape on there now so I will need to get ride of the glue residue. Should I use something like goof off on that?
Thanks
sphelps
If I can just get it out of the drive way ! LOL !
GT1000000
Thanks
Not too familiar with that particular primer, but it should work...
I have read that some guys use a vinegar solution to clean the aluminum before priming???...
For aluminum I try to use Zinc Chromate Primer, has a greenish/ yellowish tint to it...but that's just me...supposed to adhere better to aluminum???
The sticky stuff on there might come off with goof-off or you might have to get a little more brutal with it...
Maybe try and cut some of off to thin it down with a single edge razor blade, or try some laquer thinner, a wire wheel, or you could use one of these in your drill...
jbcurt00
Try several different things, rubbing alcohol worked best on last old tape residue I needed to remove....
If it's BARE aluminum, I think it needs to be sprayed w/ Zinc Chromate 1st, some are labeled w/ just the ZC. Then that Self Etch primer should work......
sphelps
The etching primer wont mess up the ZC ? I also have the valspar Oil based metal primer . The finish paint will be the valspar with hardener I guess ...
Who carry's the ZC ?
jbcurt00
Well here's an interesting read right here on Iboats & WOG was a frequent poster
Then there's this too.... See item #10:facepalm:
There's too much info in here for me even to attempt to keep track, clearly..... And I regularly reference that How to page..
sphelps
Thanks jbc , sometimes the info here goes all over the place and makes your dizzy !
You read a bunch of stuff and after thatyour still confused .. LOL !
ezmobee
I was able to find Duplicolor's etching primer at Pep Boys pretty reasonably. Light dusting is all you really need. That Rusto stuff you got should work just fine. The only product you need to watch out for is Rusto makes this weird aluminum primer (not in rattle cans) that says it's latex on the can. I can't imagine that would be good to use.
Woodonglass
All you need to do is...
Go to lowe's and get some TSP(Tri-Sodium Phosphate) Mix in warm water and scrub it down. 50/50 vinegar wash down. Light Coat (should be able to almost still see the aluminum) of the SE primer. Prime with the Rustoleum Bare Metal Primer, two Coats, Wet sand final coat. Light wipe down with Acetone, Shoot Final Color Coat. Done!!!!
sphelps
50/50 Vinegar and water ? Can I substitute Rusto Bare Metal Primer with the Valspar Oil based metal primer that I have?
BTW Tractor Supply store is fading out the Valspar paints and going with a paint called Majic . Hardener and reducer also..
Thanks !
