Re: Problem with 1998 Tracker 75 by Mercury Marine
From 92 - 99 they were mercury ignitions. If you go to outboardignition.com there are troubleshooting guides to try to isolate the problem. it could be switchbox, coil packs , trigger , or stator. basically you have to check everything and you will need a dva meter and possibly a test harness. I have the same motor except a 90hp and i have done basic troubleshooting without the dva and harness. good luck
dave
