things needed to build
2 5" section of 3/8 braided fuel hose
1 2" metal tire valve stem
1 Brass T fitting
2 couplers For T to hose connection
1 2" Aluminum bolt & aluminum ny-lock nut
1 3/8 o-ring
4 small hose clamps
The aluminum bolt & nut are available at auto parts stores
DIRECTIONS: cut head off aluminum bolt place bolt in a vise and drill thru lengthwise. thread ny-lock on to bolt backwards then put on o-ring. place coupler in brass T and hook up both hoses, push metal tire valve in one hose & bolt set up in other. clamp with clamps. screw on gauge and its done.
use a tire pump or hook a tire air chuck to your air compressor and give it a couple quick shots.
1 Brass T fitting
1 3/8 o-ring
4 small hose clamps
