Re: Mystery to be solved - reward to whoever gets it!
New update:
I took a LARGER galvanized tub ...(the type they put water in for cows on a farm) and had to cut a small notch in the front but it went under the boat real good. The water level comes up about an inch and a half past where the water pump housing is.
Started the engine and clear hose ran SOLID water .. no bubbles at all ...also no bubbles in the lines to the manifolds.
There were a few steam bubbles went through the manifold hoses as the tstat opened but only for about 5 seconds then everything went back solid and now the manifolds stay real cool ...both of them. I still have the cross rig on there and the Port Manifold (after engine up to temp and running 5 minutes) was 109 and starboard was 98 ! Which would be reversed when the hoses go normal.
OK Don, so does this confirm the leaking water pump base?
Also like I was saying the exhaust doesn't really show any bubbles in the tank until (earlier I said 2K but I rechecked with this tank) about 1500 rpms.
Is it going out through the transom ports until then?
BTW the water out the transom ports with this new tub setup POURS like crazy out both ports.
Seems llike it is OK but I should be able to run this on the muffs without any air being sucked in ...right?
I think a trip back to the water pump is in order.
Thoughts?
Kirk
			New update:
Thoughts?
Kirk
