glenn property of pam
- Feb 17, 2012
- 2,906
Re: need a sticky/link on how to use a basic volt meter
"12V is easy .. GPOP . .. "
sometimes 12v on here is like pulling teeth. the basics like testing the meter on the battery to ensure it works takes a act of congress. then theres also the ones who go test crazy trying to use resistance to find a amp draw then want someone to explain where the 20 meg ohm reading they are getting is coming from. i was never looking to teach anyone how to use the meter i was looking for a refrence that shows someone how to set and preform a test so they could tell us the results of the test. try to explain how to put a meter inline from the positive side of the battery to test for amp draw normally leads to explaining how to replace the 10amp fuse in the meter and we get results from tests all the time that go against the laws of physics. i blame the modern volt meter for being way to complicated with to many options. after last night trying to help someone it finnaly clicked that some people will never get the basic idea of 12vdc so im not sure if there was a step by step guide on how to hook up a meter they would be able to follow it.
once you understand that some people can not get to grips with 12vdc then you know that theres no way we are playing with shore power other than to link them back to the code book for marine wiring
