ok so i need some help . i have a 1977 Johnson 55hp 55el77d and it wont idle right . it will idle now but in gear i have to push the choke every so often. but it will idle in gear when i run it around full throttle for a bit but as some as it is off for 5-10 mins it starts acting up . so i rebuilt the carbs and also put a new feul pump on . nothing different and when i pump the primer gas comes out the carb . and i just found yesterday the the motor isn’t charging the battery now so any suggestions that would help thanks .
