Re: No Reverse
Do you know what causes the load sensing lever to move twice? I know it has some spring mechanism that puts in under tension when it begins to move. But as the throttle remote is moved forward the lever returns to the center position. I couldn't see what caused this. I have the manual but I haven't located a section that describes it's movement other than to say the shift interrupt lever should rest in the middle of the v-notch. I assume what ever makes it move twice is either out of adjustment like you said, or binding.
BTW, the esa was eliminated with the conversion to the Delco Voyager electronic ignition, as well as the overstoke switch.
Lets get on the same sheet of music.....
Is what you're calling the "Load Sensing Lever", #37(shift Actuator) in the picture below?
Now, to understand how it should work, notice that when the shift quadrant puts a linear (push-pull) force on the cable, the Shift Actuator will try to move against the Shift interrupter Spring (#40).
This is because the cable is held in place slightly offset from the center (1/4"-1/2" or so) of Shift actuators "Pivot Shaft" (#38)
In reality, the shift actuator would probably move a little every time you move the shifter up front, but when going into (either FWD or REV) gear, the force required to actually shift the drive shouldn't be enough to completely overcome the Shift Interrupter spring.
(Like LouC says......."it should shift with 2 fingers".....and my previously installed King Cobra DID!)
Now since the shift DOGS are slightly undercut (2 degrees on early models, 5 degrees on later ones etc) The force required to pull them apart is going to be (and should be) much higher!....... so high that the engine torque must be "interrupted" briefly while you are holding pressure on the shifter with your hand. ......... (and the Shift Interrupter Spring will be fully "depressed" actuating the ESA)
The ESA pulses your ignition and the shift Dogs separate during a brief "torque-LOW"
It's probably not as important when the cable is in tension but when it's compression, you can only "push" so hard on the cable before it begins to cause problems to the cable and/or jacket......
This is why the OMC drives ended up with the ESA. Simply interrupting the ignition apparently didn't provide enough torque drop to reliably separate the dogs every time....they had to design an electronic device to cause torque pulses because an interrupter would just kill the engine before the dogs would separate.
dogs are sometimes hard to separate....
:facepalm: ......... you have to spray water on them and keep your fingers away from their mouths!!!!)
Anyway, if yours has the 5 degree (under-cut) dogs they might be even harder to separate without an ESA)
Since you removed yours.....I don't know how you're going to get it to work well and reliably. ........ It may work for a while but the cable may bend in compression when trying to get it out of the gear requires "pushing" on the cable..........
