Re: No vocals coming thru on Amp?
It's real simple...It's called process of elimination...If you have a known good source and you plug it into your amp with known good wiring and it still does the same thing(and its true that there aren't any crossover switches, or crossovers in the speaker wires) then your amp is bad...I have my droid x plugged into my Alpine CD player in my truck with a 3.5mm to RCA and its old...when you bump it hard or twist the wire or pull a little while its playing, all kind of weird things happen...
It would be quite an amazing property for wire to be able to conduct the music between the recorded playback device and the loudspeaker amplifier but somehow not conduct the vocals. Could you explain the principle on which the wire would possess the ability to discriminate between which electrical signal it should conduct and which electrical signal it should not conduct based the the musicality of the signal?
BTW people are making things way to complicated...The only "principal" that's involved, "Is the hardware good, or bad" knowing what I know about car/marine audio installation I personally think you have a bad amp, and I was trying to show a way to prove it...
