I have an 87 mercruiser with a 454 and a 2001 bravo 3. I have never had the motor and the outdrive in the water and was going to try and do something this weekend with it. I hooked the muffs up to the lower unit turned the water on from the water hose and let the motor run for a bit and it never even got water up to the circulating water pump. "I replaced the impeller on the raw water pump the other day b/c the pulley had locked up and would not turn. Opened up the raw water pump and the impeller was shot." do i need to take it to the lake and put the boat in and run it to see if it pics up water? Does it need to be primed somehow? I can tell you that the muffs were not big enough to cover all the holes on my lower unit.. could that have been my problem that air might be getting in? thanks for your help
