Oil vs Gas Heating
tommays
Re: Oil vs Gas Heating
Well
Just last fall the crew was at my neighbors house with a huge crew digging up the soil 6' deep with a DEC guy watching
I do not want to think what that cost and any kind of under ground tank is a HUGE issue here
scrobo
Given it's already installed and relatively new, I'd use it until it was ready for replacement and then decide if you wanted to stay with oil.
Oh yeah, I meant to ask, the tank isn't buried in the ground, is it?
No. It is an indoor tank 900Litres in the basement. The oil lines are plasticized and ran under the floor to the furnace and the water heater.
SS MAYFLOAT
I've got an old Magic Chef oil burner. I service it myself (I'm a tech) every two years. My main source of heat is the wood burner. The last time I bought oil was Sep 04 @ $1.89. Hate to know how much it is now. I still have about 70 gallons left, but I sure have burned a heap load of wood. I like using wood cause I can keep the house between 76 and 78.
Oil heat is considered to be hotter than gas, propane, and electric. When I do use the oil burner, I keep my stat set at 70. If it is 15 to 20*F out, my furnace will cycle on for 5 to 10 minuets and off for about an hour. If it is 0* out, It will run for about 15 to 20 and off for 40. I heat about 2400 square feet, so I don't think the efficiency of my old unit is too bad.
Now I'm hearing rumors that the EPA is wanting to make restrictions on people like myself that burn wood. Come on,,,,,enuff is enuff...If these people who complain about the smell of wood/coal lived back in the pre 1950's, then they would know just how much pollution was back then compaired to present times..........SS
Caveman Charlie
A underground barrel is different. They can rust out and leak and if they do your screwed.
