North Beach
- Sep 29, 2008
- 2,022
Re: Old 18' starcraft what is she
86 those guages are standard Mercruiser 60's era stuff. I ended up with three sets of them. You can swap that key switch out with a newer one on the tilt panel. Tilt will work whether it's up or down with center being off. The outdrive has tilt only no trim. BTW, your outdrive setup is called MC Type 1A. You hear folks talking about Type 1ABC-the B & C are for the 120 and I think 150 HP models. Not many folks know much about them these days. And the outdrive was white back in the day.I just noticed this today the tilt switch has a key switch on it. Any one ever seen one like this.
I had a pleasant suprise to day i had to clean the connections on a few thing but other than that it all works. That does not normally happen with a 44y/o anything.
