Re: Old Cable Steer Q...
			Bob?thanks for the tip.  Looks like I?ll go down that road using those clamps.
tashasdaddy?hmmm?I was a Lowes just yesterday looking at clamps.  I didn?t see any like those in the image.  I?ll swing by HomeDepot and have a look.
Also, I noticed in the links you provided that the jacket on the cable was not striped back prior to securing with the clamp.  I was under the impression that you were supposed to strip down to the cable to secure the clamp?or does it really make any difference??
Thanks again folks?
Ill jump in , on that question for tashasdaddy
I never did cut the coating back and didnt notice any ill effects..., BUT, it makes good sense to do that...you will get a better bite.
the biggest issue is where do you cut to??, because once you get it a little set and pull it through and tighten..it is too late...you could set it up so it fits nice, then mark and undo, and cut ..then re assemble
but i dont think it is worth the hassle...
if the boat stays outside in the sun a lot, the sheathing will crack...unless they have better quality cables than I have bought in the past.
good luck
bob
