Re: OMC 100:1 mix ratio retract to 50:1 question
The thing about Chrysler was that they bought West Bend which had already been owned under a different name--I just heard it recently but, of course, forgot it. So the design is probably 60 years old or more. (Chrysler bought them in 64 so do the math.)
The basic design is OLD no doubt about it. It is the simplest crossflow design you can make. As such, It will not produce the same power from the same cubic inch displacement as more modern designs and really can not be upgraded too much. Port work will boost horsepower some, but in the end, you still have an underdog. The two exceptions would be the
1. Racing 135 and 150 with water cooled and tuned exhaust stacks and
2. The (late Chrysler) designed twin carb 55, 60, and 65 series two cylinder engines. Had Chrysler not nearly gone bankrupt and had they been able to extend this design to their larger engines, you would still see Chrysler outboards, and they would most probably run rings around OMC and Mercury.
The old design 55 weighed 156 pounds--the lightest 55 ever on the market and even though simple in design my 1967 model would outrun the three cylinder 55 Evinrudes of that era.
My admiration for the three engines actually designed by Chrysler is great. These engines had TREMENDOUS low end torque--to the point where if under-propped, they would strip out lower unit gears on a hole shot. Top end wasn't too shabby either.
For the late 70s and early 80s (last was made in 84) they were cutting edge design in crossflow engines--large bore, massive crankshaft, packed block, long beefy rods, large bearings, BIG ports, equal length and separate exhaust runners for each cylinder, through (piston skirt) induction and large venturi area. Chrysler engineers really did their homework on these engines.
I only wish That it were at all possible to modify some of the components to fit the 3 and 4 cylinder engines--well, it is possible, but it would take cubic money and more time than I have available.
I just sold my 55 for a song, but my 60 has other plans. It is eventually destined to be mounted on my 1971 15 foot Glastron and I expect that because of its reduced weight, it will outperform the Chrysler 90 that is on there now.
