jpwilly
- Jun 15, 2011
- 95
Like many owners of these rare sterndrive setups I've come to appreciate the info available on the internet. So the purpose of this thread is to hopefully help others with the same issue(s) I have encountered on my boat.
The Ford 2.3L "Pinto" engine marineized by OMC and mated to the "Cobra" sterndrive. My 88 bayliner 1750 has been down on power. I knew when I got the boat it had cam lobe wear. The previous owner said he hadn't gotten around to changing out the cam. So I just installed new rocker arms to get me through the season last year. But now I wanted to fix the boat.
I've found that these motors have the same engine block / heads that were used with the Rangers and Mustangs LX of the time, to name a few. But those vechicles started to be fitted with a roller cam setup and a pre 95 roller cam with 3/8" valve stems will swap directly to these heads. I purchased a good used roller cam, with lifter and roller rockers on ebay for $100 and pulled out the old cam out this evening. So far it only took >2 hrs to tear down and I'm waiting for the parts I purchsed to arrive to install them.
Teardown was simple (follow the manual) :
1. loosen the shift / throttle cable mixer assembly
2. label and disconnect spark plug wires
3. remove valve cover
4. loosen the alternator and remove accessory belt
5. remove the water pump pully
6. remove the timing belt cover
7. loosen the timing belt tension (don't remove the bolts just loosen)
8 remove the timng belt from cam pully .
9. remove the rocker arms...I used a long slotted screwdvriver like a pry bar to pop them out.
10. remove the cam timing belt pully
11. remove the cam retaining plate on back side of cam (two phillips screws)
12. carefully remove the cam as to not damage the camshaft bearings. The camshaft seal will most likely need replacing so just pull the camshaft out and down worry about damaging the seal. I just pryed the seal out with a slotted screwdriver.
Some pictures:
Lobe wear:
Rocker Arm Wear:
Cam removed:
Scrap metal:
Some pictures:
Lobe wear:
Rocker Arm Wear:
Cam removed:
Scrap metal:
