I have an 84' OMC "Stringer" 400 Stern Drive 2.5L 4cyl. Does anyone have any experience with converting this model to electronic ignition?? I just ordered the Pertronix Ignitor II kit with the Flamethrower II coil as a nice little upgrade cause I am tired of replacing points every spring and want to enhance reliablity and performance.
My question is: Do you need to make a special mod (Consisting of two diodes in series and two resistors in parallel between - of coil and ESA and engine ground) and install for the shift assist to work on this model? I have the mechanical shift assist (Cable and finger slide under contactor to interrupt engine while shifting)(I believe the 80-86 year models were equiped with this before OMC Cobra was produced) .....Even though the contactor is electronic...They call it mechanical shift assist.....But?? I have read of some people dropping them right in and working and others that have had problems....Just trying to clarify what I need to do and any help would be appreciated.....
