Opinions needed - Risk of Changing Thermostat
FishAtFive
I have a 1987 50hp Evinrude. E50TLCUD.
At operating temperature the head reads about 140 degrees max. The pee flow is pretty much constant, doesn't change, cold, warm, hot, doesn't matter. This motor has a history of brackish water, and getting the lower unit bolts off, I snapped three of the four.
I am debating if it's worth the risk of changing out the thermostat and possibly snapping a bunch of bolts, or it's better off just to run with a potentially stuck thermostat.
Thanks, I appreciate your wisdom on this.
Crosbyman
personnal decision... but if the thermostat is 38 years old you could always risk it.
heating surfaces around bolts with several and the patient application of a release agent will sometimes make it easy or almost. Let the capilary work do its work patience brings joy. sometimes a short clockwise jolt from a small 1/4 inch impact driver can break the bond then go CCW.
I have used and found Dupont brand snowblower silicone spray to be very effective with it's high capilary coefficient .
saltchuckmatt
Probably would have ran some chemicals through it but since you snapped the bolts you have your work cut out for you. I'm also in bracket water and I always heat the crap out of them...and when I say "Hot" I mean hot.
Then I use children's crayons on them.
Best way to get yours off is to weld a stainless steel not on it...I do it with a small 120 stick welder.
FishAtFive
No I haven't started the job yet, just debating if I should. 14 bolts!
FishAtFive
There's more bolts than 4 on the gear case, look for the hidden one.
I would not run it with 3 broken bolts on the gear case.
No I'm talking about the cylinder head cover I need to remove to get to the thermostat. 14 bolts. The three bolts I broke getting off the lower unit I got out fairly easy with vice grips.
saltchuckmatt
I understand, but there should be at least 5 bolts to get the LU off.
kbait
If head heats to 140, thermo is obviously opening as it doesn’t overheat - and it is not stuck open as it’s getting to proper temp. I would run it, and just confirm the 140 operating temp occasionally, to confirm thermo isn’t stuck open..
FishAtFive
Thanks, some really great information for me to leverage here. Much appreciated. Here are some pictures of the bolts current condition. They definitely look like they have been removed in the past.
IMG_20260111_184456735_HDR.jpgIMG_20260111_184450782_HDR.jpgIMG_20260111_184357165.jpgIMG_20260111_184351917.jpgIMG_20260111_184340649.jpgIMG_20260111_184504922_HDR.jpg
FishAtFive
Salt water motor ?------Test the overheat horn.
Yes it's good. I found out the bad way it works and have tested it since. But this reminds me of another problem with this job, that sensor is no longer available if I damage it (0386686 - Temperature Switch).
I would say there are 100's of good used ones available.----Just need to search in right places.
saltchuckmatt
I figured because the paint was chipping off the bolts it meant they've had a wrench on them. But I am here to get feedback, so you think that is just normal paint chipping?
Unless you see "wrench" damage I'd say "No". Just normal.
Wire brush, acetone chemical bath...black rattle can and get some on your fingers! 😊
