Paint????
Woodonglass
Re: Paint????
1 qt = 32oz of paint, 1 1/2 cups of Acetone = 12oz and 2 oz of Hardener.
maagee79
Re: Paint????
I just got first coat of primer on seems to be drying really fast can I sand it a little sooner and put second coat of primer on sooner?
Re: Paint????
Ayuh,... So long as it's dry to touch, Go for it...
Yacht Dr.
Re: Paint????
What Primer did you apply ? erm.. Primer on Primer without sanding .. ( If you have time to post here then you might be out of time to 3 coat primer .. )
Depends on the Primer coat .. again.. What primer did you use ?
Nomally I can coat 3 passes of prime coat..then sand with 320-400 ( Paint prep ) after 24 hrs ..
dunno what your prime coat is and your "window" coats are ..
YD.
PS. I never sand between Prime coats .. its all wet coats for primer and paint .. ( wet coat primer..sand/prep 320-400 then paint ).
maagee79
Re: Paint????
I put on first coat at 9 getting ready to go back sand a little then next coat and hope to put first coat of paint on this evening if possible.
Raystownboater
Re: Paint????
For a cheap paint job it's tough to beat good 'ol Rustoleum.
I've seen examples of paint jobs done with rustoeum and they are unbelievable! Looks like it came from a professional shop but it was done with a roller and buffed out.
Woodonglass
Re: Paint????
Yep you can wet sand the primer about 4 hours after applying. You should be able to put first Finish Coat on this evening. The Rustoleum Primer Flashes pretty quick especially with the acteone thinner.
Yacht Dr.
Re: Paint????
Again..which primer did you use ? 9 today .. sand a little.. ?? Your going to prime/prep and Paint all in one day ??
Is this like rattle can primer .. or 2 part primer ??
I think its too soon myself..most primers need to gas off before you paint ( unless its in a can stuff ) ..
YD.
Woodonglass
Re: Paint????
YD why don't you read the thread!!!! He is using Rustoleum Professional Oil based primer with Acetone thinner. Something you have never used.
Yacht Dr.
Re: Paint????
WOOD why dont you direct me to the Post # where the OP stated he used Rusto Primer !!!!! ( your assuming he did from suggestions posted ) .
I see lots of "suggestions" but never a solid answer of what he got ..
I see that the OP bought paint..then some More Oil based paint after that..
What kind of primer did he use ??
Just was asking to conferm data .. no need to get all " !!! " and stuff..gesh..
YD.
maagee79
Re: Paint????
I used exactly what I was told to use. Rust-o primer especially for the paint I bought. I do have another question in spots the primer looked like gritty looking on boat I'm sure its the way I was spraying can u tell me what I was doing wrong or do I need to adjust the sprayed?
Woodonglass
Re: Paint????
Sounds like you need to clean the gun. The Paint will SET UP in the air outlets in the nozzle and can cause it not to Fan the Paint right. Gotta watch it close. Keep a damp acetone rag on hand and keep wiping the nozzle frequently to keep it clear.
maagee79
Re: Paint????
Ok thanks. I finished second coat of primer. Gonna let it sit tonight gonna go out on river awhile. I cleaned gun an am soaking it in mineral spirits over night. Tomorrow start painting. I will take pictures tomorrow. I always forget too excited about getting it done. Should I not do anything in-between coats of paint?
maagee79
Re: Paint????
Also is it ok to put on a coat one day then the next coat two or three days later?
