jimmy wise
- Sep 6, 2012
- 288
how long between coats? you said it was light blue. did you put blue on real dry or primer dry? maybe its delaming between coats. get me a close up i might be able to tell
I'll give that a shot.I don't think 2 days with the Tractor paint is gunna be long enuf to keep it from lifting with the tape. I think you'll need to wait a minimum of at least a week or two before you try taping it. I'd also recommend thinning it with a 50/50 mix of acetone and Mineral spirits mix it well and then add the hardener and let it cook for 30 mins stirring every 10 mins.
The lady gave me a free sample of the stuff with a little thinner.Omni is PPG's value line, but the MBC requires a clear coat, which you dont really want on boat. The Omni line is ok, but you should go with OMNI single stage acrylic urethane, instead of the base. Is kinda thin compared to their concept line, but way more affordable....you my get some bleed thru from the flames with either the mbc and clear, maybe less with the SS, its thicker..a seal coat would solve that...OMNI has a few sealers, and a surface cleaner In
their system.
the older OEM enamels were acrylic enamels, not sure how it will lay over the tractor alkyd..but I suppose you could try it...
Thanks zool, I didn't catch that. No i didn't get any clear.
I was favoring the base coat clear coat because she said it is more forgiving if I get a run or something, that I could just sand it out and re spray.
Why no clear coat on a boat?
