Please help with HPDI issues
Stilletto
Got it in today, haven't had a chance to install it yet. If it doesn't solve the issue, the same seller has tons of mint parts that I may need also.
Stilletto
Didn't work.....runs the same exact crappy way.
I noticed that when I pull several spark plug wires, there isn't much/and effect on the way it runs even in gear
99yam40
those motors limit RPM in neutral by cutting off more cylinders that just the 2 it drops in neutral
make sure the motor knows when you put it into gear.
it may not be getting the signal it is in gear
Stilletto
I also noticed that if I pull each injector wire (one at a time) the rpm picks up and smooths a little. This suggests to me a global over fueling situation, or inconsistent spark.
99yam40
what tells the ECU the motor is getting proper fuel on these motors?
does it have an O2 senser?
maybe nothing.
it depends on the High pressure pump regulator to have the correct pressure.
did you make sure the ECU knows when it is in gear yet?
Stilletto
It does have an O2 sensor. It tests OK and I cleaned the "sniffer tube". It was quite nasty. I will check the neutral switch operation thursday in YDS. I did have a problem with it before but I had it working last time I checked.
