I have a 2006 Lincoln Navigator (2-wheel drive - rear). When I attempt to pull my boat (2005 SeaRay 240 SunDeck, 6000# includ. trailer) out of the water on an inclined launch ramp, the Navigator will pull it about 10 feet or so, and then sometimes lose all acceleration and start rolling backwards (until I press on the brake).
The engine does not rev or stall / shut-off...It just idles and won't accelerate. I tried shutting the traction control off, but this doesn't help. After several attempts (sometimes 5-7 attempts), it eventually successfully moves the boat up the ramp.
- This occurs whether I try to climb the ramp in "Drive" or first gear
- This issue only occurs when towing the boat up the launch ramp.
- No dashboard lights come on.
- I initiate my climb up the launch ramp by pressing the gas slowly as I release the "regular" brake.
Does anyone know what could be causing this problem?
Thank you!
Morgueman (Eric)
Thank you!
Morgueman (Eric)
