jam1ej20
- Mar 31, 2009
- 111
In the process of pressure testing my 1995 alpha 1 gen II drive and it seems to hold pressure. Only problem is that it leaks when I wiggle the lower shift shaft. Is this normal/acceptable? Or should I go ahead and replace the shift shaft seal? If so, can I replace just the seal or should I replace the shift shaft bushing assembly? Thanks guys
