i have a 1973 evinrude 25hp that has a oil leaking from a small hole left to the lower unit plug you check the level at. my guess is that its taking on water but my question is where to i hook a fitting to pressure test the lower unit for leaks?
the lower unit was leaking before the repair we put a new seal in under water impeller and new spaghetti seal i was advise by the boat shop to use sealer on all the o-rings when i reassembled everything. after the repair about 10 minutes had i together refilled with 80-90, set the engine in 55 gallon drum and run it notice lots oil floating top of the water some said could be my fuel/oil mix i did notice the oil leaking from the hole was blackish i know new gear oil couldnt turn black that quickly
